prop shaft
mfg680
#1 prop shaft
Post by mfg680 » Fri Sep 27, 2024 4:47 pm
876230 (Nov 1961 LHD DHC) is coming along well but I've painted myself into a corner. Engine and IRS look great in place but now I discover that I have to remove one to install the prop shaft. Has anyone cut the top off the inside tunnel for this purpose? It could be neatly replaced with plates and screws and, when covered with carpet, could not be detected. It would also be easier for the next owner to accomplish this task. Would this be a sacrilege or is it a common practice?
Mitch
Allrand
#2 Re: prop shaft
Post by Allrand » Fri Sep 27, 2024 5:06 pm
IMO it would be sacrilege, but apart from that it contributes to the structural rigidity of the monocoque.
Randall Botha
#3 Re: prop shaft
Post by Gfhug » Fri Sep 27, 2024 5:18 pm
:yeahthat: :banghead: :banghead: :banghead:
The IRS is probably the easiest to remove
Do you not have any of the restoration books shown in the knowledge section? There are several that will help you not paint yourself into a corner again. Also the restoration threads are well worth reviewing.
#4 Re: prop shaft
Post by mgcjag » Fri Sep 27, 2024 5:55 pm
And ensure you fill your diff ....Steve
mfg680
#5 Re: prop shaft
Post by mfg680 » Sat Sep 28, 2024 12:53 am
Thanks, makes sense, appreciate your reply.
Mitch
