Rear brakes
alunwill
#1 Rear brakes
Post by alunwill » Sat Jun 14, 2025 7:04 pm
I had a quick look at the pistons on my rear brakes earlier today. Three of the 4 pistons were well corroded, so it looks as though it's replacements for all.
I read on the forum that some members have used the front 2-1/8 on the rear when they've uprated the fronts to 4 pots because it brings front/rear balance closer to design.
As I need to buy new for the rear, is it advisable to go 2-1/8 or stick with the standard size.
I've have zeus 4 pots for the front.
Advise would be appreciated.
Alun
Al
Series 1, 2+2
undergoing renovation
#2 Re: Rear brakes
Post by abowie » Sun Jun 15, 2025 12:00 am
Have a look at these https://mossmotors.com/8777-2-cp-cobalt ... t_products
WRT balance calculate your front caliper total piston area, then see which of the available sizes gets you closest.
The stock calipers have 60% front bias.
angelw
#3 Re: Rear brakes
Post by angelw » Sun Jun 15, 2025 1:09 am
Hello Alum,
I can't see that at all working. The rear brake caliper incorporates the Hand Brake mount, which is not included on the front brake caliper.
#4 Re: Rear brakes
Post by abowie » Sun Jun 15, 2025 6:01 am
It does. You just put the 2 1/8" cylinders on the rear caliper body.
alunwill
#5 Re: Rear brakes
Post by alunwill » Sun Jun 15, 2025 3:54 pm
Hi Bill,
Yes it should work. I've checked the cylinders and the fronts (2-1/8) do physically fit the rear. Awaiting information from zeus about the size of their 4 pots.
Has a done done this already.
Alun
Al
Series 1, 2+2
#6 Re: Rear brakes
Post by abowie » Sun Jun 15, 2025 10:23 pm
Alun
Yes this is what I did when I fitted Coopercraft front calipers to my first E Type years ago. Moving the fronts to the rear maintained the brake bias at stock.
To be honest though I really couldn't feel any difference with the braking for day to day driving.
40GT
#7 Re: Rear brakes
Post by 40GT » Mon Jun 16, 2025 6:52 am
Does the S2 rear system offer any volume change?
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
