Torpedo armrest screws
Knightrider
#1 Torpedo armrest screws
Post by Knightrider » Sun Nov 30, 2025 1:16 pm
My Series 1 2+2 has torpedo-style armrests. I am trying to figure out the correct size screws to fit them - they currently seem to be fitted with a variety of different wood screws...
Does anyone know a source for correct size screws? Thanks.
1966 Series 1 2+2
#2 Re: Torpedo armrest screws
Post by mgcjag » Sun Nov 30, 2025 2:48 pm
Hi Simon..have you looked at the parts catalogue for the part number...then check on that....Steve..ps you could remove the door cards and check the threads assuming they arnt damaged...but if someone has used wrong screws the threads could be damaged and need repair
Knightrider
#3 Re: Torpedo armrest screws
Post by Knightrider » Sun Nov 30, 2025 3:23 pm
Annoyingly the MR catalogue shows the screws coming with the handle, and doesn't lost the screws separately.
I might just re-tap the threads to M5 which seems to be the closest.
1966 Series 1 2+2
tim wood
#4 Re: Torpedo armrest screws
Post by tim wood » Sun Nov 30, 2025 3:38 pm
I have a recall that mine were 1/4 unf. I used Allen headed bolts
Knightrider
#5 Re: Torpedo armrest screws
Post by Knightrider » Sun Nov 30, 2025 6:55 pm
1/4in definitely too big. Looks like they are just smaller than 5mm...
1966 Series 1 2+2
#6 Re: Torpedo armrest screws
Post by mgcjag » Sun Nov 30, 2025 7:04 pm
Probably 10/32... Steve
tim wood
#7 Re: Torpedo armrest screws
Post by tim wood » Sun Nov 30, 2025 7:53 pm
I stand corrected!
tim wood
#8 Re: Torpedo armrest screws
Post by tim wood » Sun Nov 30, 2025 7:54 pm
I stand corrected!
Apologies
Knightrider
#9 Re: Torpedo armrest screws
Post by Knightrider » Sun Nov 30, 2025 9:07 pm
I'll order some 10/32 unf and see if they fit...
1966 Series 1 2+2
40GT
#10 Re: Torpedo armrest screws
Post by 40GT » Sun Nov 30, 2025 9:59 pm
They are 10/32 unf, mine are pan head Pozi about 1.25 inch long.
Sean
S1 2+2 1966 BW RHD
XK120 1954 comp LHD
#11 Re: Torpedo armrest screws
Post by abowie » Mon Dec 01, 2025 12:56 am
From experience I'd recommend you use hex heads, or at least Philips head.
A flat head slotted screw can be hard to keep aligned in the recess in the armrest.
Knightrider
#12 Re: Torpedo armrest screws
Post by Knightrider » Mon Dec 01, 2025 11:03 am
Thanks all. Will try hex head if I can find some!
1966 Series 1 2+2
