The Throttle linkage has play and this noticeable when trying to reduce the idle speed. Having cleaned the linkage, it is noticeable the rear slave shaft Bush, (C.24816) has split and due to the high degree of movement within the bush mounting hole on the bulkhead needs replacing which has had our heads scratching how to get access to remove it.
It is hard to understand how the two parts of the Throttle linkage are mounted in the carburettor manifold and we are now faced with removing all three carburettors again to access the central Adapter, (C.18942), which supports the Front and Rear Throttle slave shafts. We assume with the three carburettors removed, we can remove the front Adapter, (C.18941) supporting the Front slave shaft, which should then enable us to remove both front and rear slave shafts from the manifold, so we can install a new rear Bush. Could this be confirmed please ?
A second issue is that all the three Throttle Spring Lever Assemblies, (C.24927), have movement around the central circlip and appear to move on the SU throttle spindle which does not assist in reducing the idle speed. We imagine the carburettor end of C.24927 would have a half circular cut out shape to match the throttle spindle, but that also shows signs of slight movement on the shaft.
We are hoping but removing and cleaning up the two throttle shafts, if they were sticking that this would assist the throttle linkage to operate more effectively and shut off cleanly, but just wondered if the slight movement in the three C.24927 assemblies was normal or if they need replacing. It was trying to understand the reason for the central circlip, which encourages movement, rather be rigidly bolted.
We would appreciate your thoughts.
