Does anyone have the resistance ranges for the following senders.
Water temp
Oil pressure
Fuel
Al
Sender resistance values
#1 Sender resistance values
Al
Series 1, 2+2
undergoing renovation
Series 1, 2+2
#2 Re: Sender resistance values
Al, you might find some very useful info by searching for “resistance”, then within the results for other words, like “water”. I did that and started to get quite a few good answers but don’t have time to do a full search at present.
#3 Re: Sender resistance values
This article may help:
https://forums.jag-lovers.com/t/water-t ... nce/427836
The fuel and water will be similar
The oil pressure sender is not a variable resister and cannot be checked with an ohm meter.
Tom
Tom
