All of a sudden I have problems with the high torque starter motor. During a nice drive this afternoon I noticed that the starter motor ran very slow when starting, just enough to start the engine (3.8; 9:1).
After cooling down outside at my home I wanted to start, nothing happened:
- battery voltage 13.5 V, dropping to 12,8 after a few attempts, remains stable
- starter relais ticks
- sometimes the starter motor comes "alive" but is not able to turn the engine around
At first glance all cabling seems to be OK, no loose connections.
First thing tomorrow is to try with starter cables.
Any ideas / suggestions where to start searching?
Starter motor issues
Ruurd Schut
Topic author - Posts: 36
#2 Re: Starter motor issues
Check the cables and the main earths.....if still faulty use jumper leads direct to starter....if still not working pull the starter out and open it up...they have large copper contacts inside that wear...but can be repaired/replaced
.Steve
.Steve
Ruurd Schut
#3 Starter motor issues
Just disassembled the starter mtor, nice job on S1.......
Test on the bench shows that the startermotor is the problem.
Ruurd
Ruurd
#4 Re: Starter motor issues
Thanks for the feed back
. Now need to fix/replace the starter motor.
Good luck
Good luck
1950 XK120 (now sold)
1953 XK120 (now sold)
1965 S1 E Type DHC (ex 2 BBC)
