Much of the steam and hot-air could have been taken out of this subject if one of the protagonists had committed sketch-to-paper and laid out the various components so that the profane could have understood even just what the original assembly looked like, and in what order parts were assembled.
I feel zero shame in admitting that much of this question remains opaque for me, but I will learn fast, and intend to render it clear once and for all.
One aspect - a critical aspect - is "what length and diameter should the spacers be", and I have seen several different sizes being used.
So, would some kind folk tell me what (if any) clearance/gap they have on the steering side, under the heads of the two safety washers ?
What kind of play did they find between the bush outer diameter and the hole in the rack ?
I have what purport to be the correct C18901 distance pieces, but they are 25mm long, which would set the safety washer about 7mm away from the face of the rack.
Same thing for the diameter - the big holes in my rack are about 16.90mm, and the spacer is about 16.10mm - which seems a pretty snug fit, and leaves not much room for quietening/cossetting my driving experience.
I think they’re wrong.
If anyone has access to parts of known provenance I would appreciate sizes.
For those who feel they already have a phD in this topic, could you explain the choice by Jaguar, for the steering-column-side location, of a three-inch SETSCREW UFS.131/24R, threaded-to-head, rather than just a bolt, when the fastener chosen for its immediate neighbour is a straightforward BOLT - UFB.131/13R.
I get the use of UFS.131/24R and UFS.131/13R on the non-steering side, which requires adjustment, but not on the side that requires simple clamped-up spacers.
Is this a mis-print (rare ?) in the J30 parts book ?
