Wheel Arch Moquette Covers
#1 Wheel Arch Moquette Covers
Post by Series1 Stu » Tue Sep 15, 2026 9:40 pm
I am about to install the Moquette covers on the rear arches on my 3.8 FHC. I have scanned here and all the restoration and originality guides I can find but I can't fully see how far back towards the rear panel they go. Do they reach as far back as the vinyl trim? Or do they stop somewhere along the way? Any photos would be appreciated, especially of original unrestored cars.
Simonpfhc
#2 Re: Wheel Arch Moquette Covers
Post by Simonpfhc » Wed Sep 16, 2026 6:57 am
Hi Stuart,
It should go right back to the vinyl on the rear panel. I have attached a photo when I was trimming mine.
62 3.8 FHC
91 Porsche 928GT
#3 Re: Wheel Arch Moquette Covers
Post by Series1 Stu » Wed Sep 16, 2026 6:55 pm
That's brilliant Simon, thank you.
I'll probably make a start tomorrow. There is a sparse amount of information out there on trimming although the CMC/David Barzilay book says it can be rather difficult.
Deep breaths.....
Simonpfhc
#4 Re: Wheel Arch Moquette Covers
Post by Simonpfhc » Wed Sep 16, 2026 8:20 pm
The key for that part is to start at that rear most corner, glue the fabric in place and then really stretch it forward. This then allows the fabric to easily stretch upwards and downwards avoiding creases.
62 3.8 FHC
91 Porsche 928GT
#5 Re: Wheel Arch Moquette Covers
Post by Series1 Stu » Thu Sep 17, 2026 10:02 pm
Ok, some progress with this. I now have both sides looking very much like your photo. I'm going to continue tomorrow with a little adult supervision in the form of my wife. She has a much better feel for this sort of work than I do.
#6 Re: Wheel Arch Moquette Covers
Post by Series1 Stu » Sat Oct 10, 2026 9:49 pm
Job done! It wasn't fun and it's not perfect but we got there. Pictures to follow.
Next step is to cover the cubby box panel. Any tips gratefully received.
Thanks for all the help.
TGN
#7 Re: Wheel Arch Moquette Covers
Post by TGN » Sun Oct 11, 2026 1:37 am
The cubby box is straight forward compared to the arches. You need the very thin felt NOT foam, just the front and top edges glued and cut flush, followed by the vinyl finish glued past the felt and on the returns. A can of high temperature spray glue is your friend for the flat surfaces felt then vinyl and contact adhesive on the returns. . Fix the centre and work out to each edge. The rear of it doesn’t need covering, a can of satin black will sufice on any edge not covered in material . But make sure it all fits and lines up with all fixing holes (fifteen from memory) before you cover it. If it’s an original panel you should be ok. I had to modify my aftermarket panel substantially
And the forward luggage panel fit should hinge nicely and secure the locating pins in the sprung metal clips when laid flat. Fit the clips with two rivets each side after applying the covering.
If you need to re-drill any fixing points in the body tub make sure you paint and protect newly drilled holes and seal unused ones, particularly the four that go into the rear arches
Trevor.
#8 Re: Wheel Arch Moquette Covers
Post by Series1 Stu » Sun Oct 11, 2026 10:09 am
Wow, thanks for the comprehensive advice, Trevor. Much appreciated.
My panel is aftermarket and I have had to re-bend the end folds to make it fit properly between the wheel arches and tweak the top bend so it allows the hinged panel to sit flat and square. As usual, we get to spend a small fortune on an ill-fitting part that you then spend hours modifying to be fit for purpose.
You mentioned using felt, not foam. I have used scrim foam on various parts, in line with advice received and as supplied in my BAS trim kit. Is there a benefit in using felt? Sorry, this is the first time I have heard this advice so I'm intrigued to know the reasons behind it.
