Post
by PeterCrespin » Fri Apr 18, 2014 3:26 pm
Does anyone think E-type bonnets are/were made/assembled to modern standards of repeatability and accuracy? I doubt it somehow. 1/4" on a width of 25 inches is 1% error, on complex curves in sheet steel. Hello?
That's why the motif bar holes are at least double the width of the fixing studs - to allow for cumulative variance. FWIW, my new bar is 24 7/8ths end to end and if it was a problem I wouldn't hesitate to trim the ends and rely on the washers to hold it as normal. After all, if it's too wide to begin with it's hardly going to slide sideways out of position.
Yes, in terms of machined parts etc. we have right to expect accuracy where it's critical, but on body panels? The old advice to sort out all your brightwork BEFORE paint still applies. At the factory they probably had jigs and go/no-go gauges for all key dimensions, to be sure that as they went down the line they were all within spec and didn't build up unhelpful tolerances. People building bodies one at a time today, 'free hand', and expecting new or old parts to fit accurately, are in for a rude awakening methinks. This ain't no Camry (thank goodness).
Time you all got Series 2s. Fortunately, I'm prepared to swap. I'm all heart, me....
