Hi all,
1966 Series 1 4.2 2 + 2: I need to remove the rear seats to get at the plates that access the rear brakes. The cushion comes out easily but how do I remove the sliding seat back rest - I think it is called the squab?
Cheers,
Roger
Removing rear seats on a Series 1 2 + 2
Roger's E Type
Topic author - Posts: 46
Two bolts in the base plate of the parallel linkage each side. It's a fairly heavy item so don't do your back in reaching over to lift it.
mystery type
once you have removed those bolts, you need to knock it up-wards to unhook the seat from the upper retaining clips.
And be careful not to rip the side cushions, the edges of the hinges are Sharp.
Carsten
Carsten
Roger's E Type
Thanks for the replies - all the information I needed!
Cheers, Roger
Cheers, Roger
Roger's E Type
Cheers, Roger
Cheers, Roger
