Moss gearbox e-type vs MK2 3.8
fredmec00@hotmail.com
#1 Moss gearbox e-type vs MK2 3.8
Post by fredmec00@hotmail.com » Sat Mar 28, 2015 7:17 am
Hi Gents,
Could someone confirm the moss gearbox from an MK2 3.8 fits an early e-type, Series 1 + moss transmission?
Thanks in advance for the support,
Fred
E-Type 1963, 880190, LHD
tinworm
Post by tinworm » Sat Mar 28, 2015 7:57 am
Hello Fred . If you are fitting the whole box - it won't go in due to the longer tailshaft housing or overdrive. The E-type gearbox is much shorter. The gears main casing and bell housing are the same though.
regards Barrie
Post by fredmec00@hotmail.com » Sat Mar 28, 2015 12:39 pm
Barrie,
I already have the moss gearbox, just need the bellhousing. But the person probiding the housing is unsure if it was from an e-type or MK2.
The only thing he knows is that it came from a 3.8
So from you previous message, I understand the housing is the same and the only difference is the gearbox?
Cheers,
Fred
Post by christopher storey » Sat Mar 28, 2015 2:00 pm
The bellhousing from any 3.4/ 3.8 will fit provided it was for the Moss box and not for the later ( 1966 on ) all-synchro transmission . What you cannot do is mix a 4.2 housing with a 3.8 engine or gearbox without changing the flywheel and starter motor as well
Post by fredmec00@hotmail.com » Sun Mar 29, 2015 8:21 pm
Thanks, that is clear!
