With respect to a 1965 E-Type FHC
At the risk of appearing over nit picky could someone advise the proper mounting of this pipe on the right hand side of the engine block. Should the brackets be attached to specific manifold studs?
Many thanks
heater return pipe
#1 heater return pipe
Wicker Francis
1965 E-Type FHC LHD in restoration
You'll find that they will only fit properly on the correct studs.
The longer bracket goes on the second stud from the front, the short bracket on the third from the rear.
Perfect, Andrew
Thank you
Thank you
Wicker Francis
