Bulkhead diagram with mounting labels
jcarey
#1 Bulkhead diagram with mounting labels
Post by jcarey » Wed Jan 25, 2017 9:57 pm
I posted this on the Jag-Lovers E-type forum and was asked by Steve to post it here. I made this based on a diagram John North created and I found on the Internet while restoring my 1963 Coupe. I expanded on it in an attempt to label every opening and threaded opening in the bulkhead/bodywork and what each is used for. I am sure errors may be present, so please double check my work before committing to anything irreversible. Best regards.
Bettie IV my 1963 S1 E-Type FHC (888373)
#2 Re: Bulkhead diagram with mounting labels
Post by mgcjag » Wed Jan 25, 2017 10:38 pm
Thanks John....im sure it will be of intetest to the forum
288gto
Russia
#3 Re: Bulkhead diagram with mounting labels
Post by 288gto » Thu Jan 26, 2017 7:57 am
Thanks for posting, one initial observation is that you have the holes used for the brake vacuum pipes (lower ones) labelled as "coolant tubes"
1954Etype
#4 Re: Bulkhead diagram with mounting labels
Post by 1954Etype » Thu Jan 26, 2017 8:22 am
The '???' On the bottom line are for the choke cable grommet on a S1 car blanked off on twin carbs. Not sure the 'rust prevention blanks' are standard.
Angus 67 FHC 1E33656
61 OTS 875047
mark10337
Switzerland
#5 Re: Bulkhead diagram with mounting labels
Post by mark10337 » Thu Jan 26, 2017 8:56 am
That's a great piece of work. Is there a version available that could be amended to the later revised bulkhead?
-Mark
jcarey
#6 Re: Bulkhead diagram with mounting labels
Post by jcarey » Thu Feb 02, 2017 2:46 pm
288gto wrote:Thanks for posting, one initial observation is that you have the holes used for the brake vacuum pipes (lower ones) labelled as "coolant tubes"
Simon,
Your correction will be added to my diagram asap! Thanks.
jcarey
#7 Re: Bulkhead diagram with mounting labels
Post by jcarey » Thu Feb 02, 2017 2:48 pm
1954Etype wrote:The '???' On the bottom line are for the choke cable grommet on a S1 car blanked off on twin carbs. Not sure the 'rust prevention blanks' are standard.
Angus,
Thanks - I'll add the choke cable grommet label to this point of my diagram. I only had one example to work with at the time and it was my 1969 FHC. It's certainly possible these rust proofing plugs were added after the factory shipped it to the Northeastern USA.
jcarey
#8 Re: Bulkhead diagram with mounting labels
Post by jcarey » Thu Feb 02, 2017 4:15 pm
Here is an updated version with your input
thanks,
Firewall 2-2-2017-smaller.jpg (254.24 KiB) Viewed 21574 times
#9 Re: Bulkhead diagram with mounting labels
Post by Gfhug » Thu Feb 02, 2017 4:26 pm
John, that's a very useful diagram. Is it possible to get a higher resolution copy?
Maybe David (Heuer) could add that to the knowledge base?
Oh, and as Mark asked earlier, is there a version for the later cars?
#10 Re: Bulkhead diagram with mounting labels
Post by Heuer » Thu Feb 02, 2017 4:53 pm
Gfhug wrote: Maybe David (Heuer) could add that to the knowledge base?
Done!
Turnip
#11 Re: Bulkhead diagram with mounting labels
Post by Turnip » Fri Feb 03, 2017 4:57 pm
Speedo cable?
Unless it's labelled differently.
1965 Series 1 4.2 FHC
Robsan
#12 Re: Bulkhead diagram with mounting labels
Post by Robsan » Sat Feb 04, 2017 9:22 pm
Do the "three holes" on LH and washer bottle on RH alternate for LHD and RHD ?
paulsco
#13 Re: Bulkhead diagram with mounting labels
Post by paulsco » Tue Feb 07, 2017 5:50 pm
They do on my car.
jcarey
#14 Re: Bulkhead diagram with mounting labels
Post by jcarey » Wed Feb 08, 2017 7:59 pm
Gfhug wrote:John, that's a very useful diagram. Is it possible to get a higher resolution copy?
I have the original file and could make a higher res version for you if you like - but I'd need to send it to you via email I think. I will send a PM asking for your email OK? I don't have one for later version cars.
Heuer,
If you would like to have a high res version for the knowledge base, let me know and we can exchange emails too.
Cheers,
mark10337
Switzerland
#15 Re: Bulkhead diagram with mounting labels
Post by mark10337 » Wed Feb 08, 2017 9:20 pm
PM Sent. I'd like to adapt it for the S2.
-Mark
Robbiee
#16 Re: Bulkhead diagram with mounting labels
Post by Robbiee » Sun Nov 07, 2021 6:26 pm
Hi all
I’m planning to do a RHD version of the bulkhead diagram for 3.8 car
Anyone interested?
Robbie
#17 Re: Bulkhead diagram with mounting labels
Post by mgcjag » Sun Nov 07, 2021 7:01 pm
Hi Robbie...Im sure it will be of great use and good to add to the knowledge base....Steve
Shiggi10
#18 Re: Bulkhead diagram with mounting labels
Post by Shiggi10 » Sun Mar 27, 2022 8:41 pm
Robbiee wrote: ↑
Hi all
Anyone interested?
Robbie
Yes please!
caveman
#19 Re: Bulkhead diagram with mounting labels
Post by caveman » Tue Mar 29, 2022 6:51 pm
Great idea and will be much appreciated.
:thankyouyellow:
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#20 Re: Bulkhead diagram with mounting labels
Post by DWW » Tue Mar 29, 2022 9:09 pm
Welcome here :welcomewave:
