rear caliper fitting ? and electric coil connection
Post by abowie » Fri Jun 12, 2015 10:08 pm
lataud wrote:The 3.8 l has not such a relay ...
C17338: http://www.sngbarratt.com/ProductDetail ... 7bbd0fbdf2 This is the correct 3 pin relay used for the fan and horn but of course you could use any relay.
Alty Ian
Post by Alty Ian » Fri Jun 12, 2015 10:27 pm
It is not currently available from SNGB. Their source dried up :x
The horn normally has a 4 pin relay.
Post by abowie » Fri Jun 12, 2015 11:47 pm
There are some on Ebay.
mjsheehan
#24 Bolt C19759
Post by mjsheehan » Wed Aug 05, 2015 1:22 pm
Hello Lataud, I'm also searching for the Caliper to final drive bolts - C19759. Did you ever find a source or identify the thread?
Polse7317
Post by Polse7317 » Fri Aug 07, 2015 9:26 am
Yes I found them, I am now at the sea side for some holidays, i'll give you the address at the end of the month...
Polse7317
Post by Polse7317 » Fri Aug 07, 2015 1:03 pm
I found the address:
Alan Slawson
E: ajseng@hotmail.co.uk
T: 00 44 7831 163158
I hope I have helped you ...
