Horn push assembly S1
adam
Post by adam » Fri Mar 25, 2016 11:57 am
The badges were only glued in and are the same size as the horn push but missing the retaining ring. Also badge too flat... needs to be ground and polished to create the correct radius to match the original. I had an old pattern horn push so I removed the retaining ring and Epoxy resined to badge and fitted.
No crazing to badge, gold not as intense as some but I am pleased with the result.
Post by PeterCrespin » Fri Mar 25, 2016 2:44 pm
Yup, that's the ticket. It's not 'missing' the retaining ring, unless you think it's missing the black surround, brass plate and spring as well. it just isn't being used as a horn push hence you have to supply the horn push bits to complete the swap. Good catch on the curvature difference although they can be used as-is. I think the colour depends how long the hub caps were in the sun?
adam
Post by adam » Fri Mar 25, 2016 3:59 pm
The retaining ring takes the brass contact, and the cut out locates the horn push to stop horn push spinning round. Also without retaining ring it would just fall out. The ring is the stop to locate it on the centre, because without it the hub cap badge is the same diameter as the hole.
Adam
Post by PeterCrespin » Sat Mar 26, 2016 9:46 am
adam wrote:The retaining ring takes the brass contact, and the cut out locates the horn push to stop horn push spinning round. Also without retaining ring it would just fall out. The ring is the stop to locate it on the centre, because without it the hub cap badge is the same diameter as the hole.
Adam
All true Adam, but the hub cap is not designed and does not function as a horn push, or vice versa so nothing is 'missing' in either incarnation
It's just that the decorative emblem part, and that part alone, can be switched from the former to the latter with a bit of work. Most will be happy with the ready-made repro part, but for those who want an original golden Jag emblem and don't mind a bit of fettling, S3 hub caps are a source of the real McCoy.
adam
Post by adam » Sat Mar 26, 2016 10:16 am
Looks like S3 hub caps might be more in demand now?
Adam
johnben
Post by johnben » Thu Apr 07, 2016 5:54 am
Hi Folks
I purchased a small horn growler push cap for less than ?5 as a straight replacement for the leaping cat which I now have, It's cheap and cheerful but looks puny when compared to the original growler which I purchased for ?62 off eBay and is in good condition. I have decided to try to put things back as they should be, the PO left me the steering wheel but nothing else. I presume I will need an original steering wheel boss, outer circle for the horn push, bits in the attached photo?s and a few parts from the repair kit. Any advice would be welcome.
1967 Series 1 2 + 2
neil4444
Post by neil4444 » Thu Apr 07, 2016 7:42 am
Hi John,
Yes, as you mention you will need the correct boss to connect steering wheel & the outer horn circle (you could buy repro & fit your nice growler - although I don't know if they're guaranteed to fit). I would just start with that initially as you may find that the other parts are already in place within the steering column (although it looks like the spring & plastic shroud may not be in place at the top of the brass plunger). Be warned that the replacement parts in the repair kit are often in poor quality 'soft' brass & it's hard to get them to remain in contact so it's best to keep originals if possible.
Neil
1962 S1 OTS
1967 S1 FHC
johnben
Post by johnben » Mon May 02, 2016 7:46 pm
Hi Folks just thought I would follow up on this thread, having purchased an original Growler badge I was then faced with the problem that I could not purchase the other parts separately, so I purchased a replica growler unit so that I could use the other bits and a s/wheel boss, including the original growler, using my own original steering wheel total cast is about ?260 which I am happy with. Now fitted and working.
Thanks fort the advice.
John Series 1 2 + 2
david muir
Scotland
#29 Re: Horn push assembly S1
Post by david muir » Tue Oct 24, 2017 1:45 pm
adam,
I've PM'd you.
David
1964 3.8 FHC
rossbraithwaite
#30 Re: Horn push assembly S1
Post by rossbraithwaite » Tue Mar 28, 2023 12:23 pm
Apologies for the thread revival; I've searched all of the horn push threads but can't find what I'm looking for. I am restoring 2 horn pushes. One I believe to be S1 ( chrome ring 54300576, brass contact ring on 54300754, copper plate 54300575) the other I believe to be S2 (black ring, no horn contacts). Does the S1 horn push have the foam disc fitted between the emblem badge and copper plate? Or, is the foam disc fitted only on the S2 instead of the copper plate?
Thanks,
Ross
#31 Re: Horn push assembly S1
Post by DWW » Tue Mar 28, 2023 4:42 pm
I have 3 S1 horn push assemblies two originals and one after market and haven't seen any foam discs in any of them while restoring.
#32 Re: Horn push assembly S1
Post by Gfhug » Tue Mar 28, 2023 7:17 pm
Ross, I think the foam is there on the S2 to give a slight cushion feel to it. Whereas on the S1 it would be an insulator stopping the horn from working. Or get tangled up with the spring, contacts, etc. That’s what my thoughts are fwiw.
