Initially I used to feel a responsibility to him, before I got stick into the car he'd restored (to the point of producing a colour brochure when he first tried to sell it) - now all I want to do is rub his nose in his cynical make-over.
Here you have some "adjustment cuts", a mixture of hand hack-saw and a cross-cut with a powered jig-saw, apparently.
Nice - never welded back of course, just left floppy.
Then Araldite thrown in massive dollops to botch the stuff together.
Questions please :
1. Are these basic ingredients indeed the original parts, especially the alloy trim ? Or have I got amateur copies from A to Z ?
2. Is it normal to have found plywood under that alloy trim ? Was the original wood as badly cut/fitted as the c-r-a-p I've discovered ?
3. Is that wooden layer also glued onto the steel box structure, at any point, or are the claws on front and the rear of the alloy skin the only things meant to hold it into place ? I can't see how with only F and R claws the skin can remain held in place along its whole length, especially in the centre areas where it has the kinks ?
4. Whilst I'm refettling the metalwork and sorting out the various cuts, could I have a go at reducing the shoulder width by 10mm at the front so that the radio/speakers console lower ears are easier to slip over when re-fitting ?
5. Am I right in thinking there are no fittings missing that would tie the front of the steel box section onto the top of the gear-box cover, and that the centre console is only bolted to the narrow transmission tunnel area in 3 places at the rear - ie 1 centre, opposite side to the handbrake, and then two at the rear, one at either side ?
Or should I just set fire to the car right now ?
