Steering Column Felts
richard btype
#1 Steering Column Felts
Post by richard btype » Sun Feb 14, 2016 8:39 pm
I removed the upper steering column (section above the universal joint /below the dashboard), due to some play, is there a method for fitting the upper and lower felt bushes, it was incredibly tight to push the column back through - I used some light grease before hand anticipating a certain amount of compression in the felt and although I managed to return the column to its position (tapping with a copper mallet) it is still tight certainly far more than would allow the steering wheel to self centre.
Any tips please? :? :?
3.8 FHC Chassis no: 860403
DOM - 11th April 1962
Also
4.2 FHC Chassis no: 1E32173
DOM - 12th December 1965
andrewh
Post by andrewh » Sun Feb 14, 2016 9:51 pm
By felts I assume you mean the black rubber like bushes? You need to ensure that the small round locating lugs are correctly in the holes in the outer column. If still tight ease slightly with small Drexel tool as they will tighten when hot. I just did some with no trouble.
Edit. If you did use felt I think I would swop to the black bushes
1962 3.8 Series One FHC
Post by Heuer » Mon Feb 15, 2016 10:51 am
If you want to use the felts you need to soak them in a jar of oil for about a week before assembly. Even then you may find the steering stiff with no self centering. The Elastollan bushes fitted to later cars can also be used but you need to assemble the column on the bench and check how stiff the steering is. You will probably have to relive them on the inside with a Dremel until you have the right amount of play. Bear in mind the shaft heats up when in the car due to the proximity to the engine; it expands which causes the steering to squeak or you loose self-centering. When the whole thing is assembled and back on the car there should be a small amount of play which will disappear as you drive.
richard btype
Post by richard btype » Tue Feb 16, 2016 5:33 pm
Thank you Gents.
Now don't laugh! I fitted a pair of the Elastollan bushes last year and assumed they were another poorly produced retro product due to the slight movement in the column - hence dismantling it and fitting some felt bearings!
Sometimes one can go out of one's way to?..
Also
Post by abowie » Tue Feb 16, 2016 11:50 pm
IMO both the felts and the replacement plastic bushes from the usuals are junk.
Find someone with a lathe to turn you up some out of Delrin or nylon. Ideally they should be about an inch wide. Once fitted you'll never have a problem again.
andrewh
#6 Re: Steering Column Felts
Post by andrewh » Wed Jan 18, 2017 12:54 pm
i have just taken delivery of a set of bushes and note that they are now more rubber like rather than the harder plastic. Not sure whether they will relieve with a dremel as with the previous type. I suppose I could put some high temperature silicone grease on them?
Moeregaard
#7 Re:
Post by Moeregaard » Wed Jan 18, 2017 1:55 pm
abowie wrote:IMO both the felts and the replacement plastic bushes from the usuals are junk.
I'll second the "home-grown" solution. I turned my own bushings from Delrin when the original bits had broken up due to age, and my supplier didn't have any in stock. Ensure that the outside diameter is a slight press fit in the tube. I ran with these for many years and they were still in the car when I sold it.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
