1) The sides of the centre console
2) The radio/speaker frame
3) The ashtray frame
4) The inner sill covers
5) The angled/vertical panel directly behind the seats
6) The cross member in front of the seats.
as it will be a relatively simple job to remove the stained rexine/vinyl (some original/some recovered) areas to improve the appearance.
My question is whether each of the above would have had a foam backing? or whether the material was simply applied directly to the surface without foam below?
