Hello,
My restoration process is mooving foreward.
I'm too lazy to report every step on the forum, I apologise for not doing it.
The car was completely dismantled in september 2016.
Body sandbladted
Several panels replaced (from Martin R.)
We are finishing the body for painting
Does anyone know where I can find the list of spot I should leave metal blank for better ground wirering when I will install a new loom ?
Thanks for help (and please excuse my approx. English)
Olivier
Reserve spot before paint for wire ground
#2 Re: Reserve spot before paint for wire ground
I didn't bother, I just used a dremel to clean back to bare metal each time I attach an earth. That way I don't have to mess around with masking tiny areas off and when I do clean it up, I know it's nice shiny clean metal I'm earthing to. I also checked each one with a multi meter for continuity just to me sure. I then sprayed over the connection with clear wax to hopefully prevent any oxidation.
