Page 1 of 2
#1 Bulkhead diagram with mounting labels
Posted: Wed Jan 25, 2017 9:57 pm
by jcarey
I posted this on the Jag-Lovers E-type forum and was asked by Steve to post it here. I made this based on a diagram John North created and I found on the Internet while restoring my 1963 Coupe. I expanded on it in an attempt to label every opening and threaded opening in the bulkhead/bodywork and what each is used for. I am sure errors may be present, so please double check my work before committing to anything irreversible. Best regards.
#2 Re: Bulkhead diagram with mounting labels
Posted: Wed Jan 25, 2017 10:38 pm
Thanks John....im sure it will be of intetest to the forum
#3 Re: Bulkhead diagram with mounting labels
Posted: Thu Jan 26, 2017 7:57 am
by 288gto
Thanks for posting, one initial observation is that you have the holes used for the brake vacuum pipes (lower ones) labelled as "coolant tubes"
#4 Re: Bulkhead diagram with mounting labels
Posted: Thu Jan 26, 2017 8:22 am
by 1954Etype
The '???' On the bottom line are for the choke cable grommet on a S1 car blanked off on twin carbs. Not sure the 'rust prevention blanks' are standard.
#5 Re: Bulkhead diagram with mounting labels
Posted: Thu Jan 26, 2017 8:56 am
by mark10337
That's a great piece of work. Is there a version available that could be amended to the later revised bulkhead?
#6 Re: Bulkhead diagram with mounting labels
Posted: Thu Feb 02, 2017 2:46 pm
by jcarey
288gto wrote:Thanks for posting, one initial observation is that you have the holes used for the brake vacuum pipes (lower ones) labelled as "coolant tubes"
Simon,
Your correction will be added to my diagram asap! Thanks.
#7 Re: Bulkhead diagram with mounting labels
Posted: Thu Feb 02, 2017 2:48 pm
by jcarey
1954Etype wrote:The '???' On the bottom line are for the choke cable grommet on a S1 car blanked off on twin carbs. Not sure the 'rust prevention blanks' are standard.
Angus,
Thanks - I'll add the choke cable grommet label to this point of my diagram. I only had one example to work with at the time and it was my 1969 FHC. It's certainly possible these rust proofing plugs were added after the factory shipped it to the Northeastern USA.
#8 Re: Bulkhead diagram with mounting labels
Posted: Thu Feb 02, 2017 4:15 pm
by jcarey
Here is an updated version with your input
thanks,
#9 Re: Bulkhead diagram with mounting labels
Posted: Thu Feb 02, 2017 4:26 pm
by Gfhug
John, that's a very useful diagram. Is it possible to get a higher resolution copy?
Maybe David (Heuer) could add that to the knowledge base?
Oh, and as Mark asked earlier, is there a version for the later cars?
#10 Re: Bulkhead diagram with mounting labels
Posted: Thu Feb 02, 2017 4:53 pm
Gfhug wrote: Maybe David (Heuer) could add that to the knowledge base?
Done!
#11 Re: Bulkhead diagram with mounting labels
Posted: Fri Feb 03, 2017 4:57 pm
by Turnip
Speedo cable?
Unless it's labelled differently.
#12 Re: Bulkhead diagram with mounting labels
Posted: Sat Feb 04, 2017 9:22 pm
by Robsan
Do the "three holes" on LH and washer bottle on RH alternate for LHD and RHD ?
#13 Re: Bulkhead diagram with mounting labels
Posted: Tue Feb 07, 2017 5:50 pm
by paulsco
They do on my car.
#14 Re: Bulkhead diagram with mounting labels
Posted: Wed Feb 08, 2017 7:59 pm
by jcarey
Gfhug wrote:John, that's a very useful diagram. Is it possible to get a higher resolution copy?
I have the original file and could make a higher res version for you if you like - but I'd need to send it to you via email I think. I will send a PM asking for your email OK? I don't have one for later version cars.
Heuer,
If you would like to have a high res version for the knowledge base, let me know and we can exchange emails too.
Cheers,
#15 Re: Bulkhead diagram with mounting labels
Posted: Wed Feb 08, 2017 9:20 pm
by mark10337
PM Sent. I'd like to adapt it for the S2.
#16 Re: Bulkhead diagram with mounting labels
Posted: Sun Nov 07, 2021 6:26 pm
by Robbiee
Hi all
I’m planning to do a RHD version of the bulkhead diagram for 3.8 car
Anyone interested?
Robbie
#17 Re: Bulkhead diagram with mounting labels
Posted: Sun Nov 07, 2021 7:01 pm
Hi Robbie...Im sure it will be of great use and good to add to the knowledge base....Steve
#18 Re: Bulkhead diagram with mounting labels
Posted: Sun Mar 27, 2022 8:41 pm
by Shiggi10
Robbiee wrote: ↑
Hi all
Anyone interested?
Robbie
Yes please!
#19 Re: Bulkhead diagram with mounting labels
Posted: Tue Mar 29, 2022 6:51 pm
by caveman
Great idea and will be much appreciated.
:thankyouyellow:
#20 Re: Bulkhead diagram with mounting labels
Posted: Tue Mar 29, 2022 9:09 pm
by DWW
Welcome here :welcomewave:
