Starter Motor replacemen
markb427
#1 Starter Motor replacemen
Post by markb427 » Fri Mar 17, 2017 11:51 am
I have series 1 4.2 the starter motor has been playing up and needs replacing. I'm planning to replace with new hi torque one but how do you get the old one out? Can't seem to access to the bolts to remove it, can you do it with engine in place ?
#2 Re: Starter Motor replacemen
Post by mgcjag » Fri Mar 17, 2017 2:36 pm
Hi Mark...not the easiest job.....it does give details in the maintenance manual.....bolts ara accesable from under the car or via access panel on right hand side of gearbox .....dont forget to disconnect the battery.....and it can help to remove the drivers seat
markb427
#3 Re: Starter Motor replacemen
Post by markb427 » Wed Mar 22, 2017 1:44 pm
Hi Steve,
Thanks for the tips, it's not an easy job but done at last!!!
