mxke
Post
by mxke » Wed Oct 21, 2020 1:29 am
Hi:
I have started disassembly of the engine and a couple of questions.
There are 5 "F" and one "G" stamping on the block beside the cylinders. I assume this was a sizing stamp at assembly?
There are a set of three letters on the block and bearing caps as well as the front cover. Is this the original assembly person who stamped these?
Thanks,
Mike
Post
by abowie » Wed Oct 21, 2020 1:52 am
Like you I think that the stamps on the caps are the initials of the engine builder and numbers to identify which cap goes where.
I haven't seen stamping on the head like that.
In a recent thread I found out that the engine number is stamped on the crank in early cars as is shown on yours.
mxke
Post
by mxke » Wed Oct 21, 2020 2:23 am
So far the block, head, flywheel and crank all have the same numbers!
Harold Lang
Post
by Harold Lang » Wed Oct 21, 2020 2:53 am
The stampings on the block gasket surface face are the piston bore grades. If pistons are original, the same stamping should be found on the piston. Simple method of maintaining correct bore clearance.
Harold
Harold Lang on Wed Mar 11, 2026 5:06 pm, edited 1 time in total.
288gto
Post
by 288gto » Wed Oct 21, 2020 8:39 am
abowie wrote: ↑Wed Oct 21, 2020 1:52 am
Not just early cars Andrew, my 69 S2 has the engine number on the crank, and flywheel too.
mxke
Post
by mxke » Mon Oct 26, 2020 11:18 pm
I see why it is a good idea to remove the sludge plugs...
mxke
Post
by mxke » Mon Oct 26, 2020 11:21 pm
All but one cotter pin was still in the castellated nut. So on the rebuild there are 12 point nuts to replace the castellated + cotter pin?
mxke
Post
by mxke » Mon Oct 26, 2020 11:26 pm
On the main bearing bolts, there is a washer to replace the lock tabs now? The engine stand idea works wonderfully!
Time to replace the con rod bearings...
mxke
Post
by mxke » Mon Oct 26, 2020 11:34 pm
Post
by abowie » Tue Oct 27, 2020 2:28 am
mxke wrote: ↑Mon Oct 26, 2020 11:21 pm
Replace all of them with new bolts and nuts.
I see you plan to replace the conrod bearings. Have you replaced the main bearings as well?
mxke
Post
by mxke » Tue Oct 27, 2020 4:06 am
They will be replaced as well.
