Front wheel bearing
PhilP
#1 Front wheel bearing
Post by PhilP » Tue May 23, 2017 7:41 pm
Can anybody point me in the right direction for this topic as I'm sure it must have been discussed before I have done a search and haven't been able to find anything. It's time to replace the front wheel bearings on my car. I have replaced plenty on other cars but never on the Etype. Do you require any special tool to remove the old bearing case and does it require a press to refit them. I have removed the hub and the old taper bearings and oil seal but the out case of the bearing are solid. I have tried to punch them out from the inside ( not too much force as I don't want to damage them until I know I can replace them. If any body has got any advice or can point me to a previous thread I would very much appreciate it.
1968 series 1.5 fhc, Ftype S for when it rains
Airborne62
#2 Re: Front wheel bearing
Post by Airborne62 » Tue May 23, 2017 11:27 pm
Just removed the old bearing races from my 62 hubs using this trick. You need a welder though. Worked like a champ. You must remember to let the weld cool and shrink.
http://makezine.com/2009/03/04/trick-fo ... ring-race/
Airborne62
'62 FHC
#3 Re: Front wheel bearing
Post by abowie » Wed May 24, 2017 12:01 am
Just use a suitable drift and a big hammer.
#4 Re: Front wheel bearing
Post by mgcjag » Wed May 24, 2017 7:59 am
Hi Phil....as Andrew says above....hammer and drift..just make sure you use something non sharp with a flat end ive used a slim chisel but flatend the end with a grinder.....you will need a hefty whack and work your way around....a press is much better for putting the inner race back in, trying to tap it in can make it go off center, but can be done... Steve
PhilP
#5 Re: Front wheel bearing
Post by PhilP » Wed May 24, 2017 8:53 am
Thanks for the replies now I know that it is just a bit of brute force I'm going to grind a flat chisel at work today with a slight curve on it to allow me to get a bit better contact. The other wheel bearings I have changed have had a bit more of a face exposed making it easier to hit and remove.
Thanks again for your replies another job ticked of the list of work done on my Etype. At this rate it'll not be long before I'm tackling a full restoration
#6 Re: Front wheel bearing
Post by chrisfell » Wed May 24, 2017 9:17 am
Go on, buy yourself a bench top hydraulic press. You deserve it!
Much easier to get a bearing square, less chance of a little bit of swarf getting lodged underneath, resulting in a skew bearing and accelerated wear, and it looks soooooo cool sitting in the bench top. Every man-cave should have one.
PhilP
#7 Re: Front wheel bearing
Post by PhilP » Wed May 24, 2017 9:49 am
You might be right about a press just been looking on eBay at them I'm sure I can find something else to press as well even if it's just grapes
