#1 Luggage strips in S1 4.2 Coupe
Posted: Sat Jun 03, 2017 5:12 pm
by Michaelg
Does any one know whether the luggage strips in an S1 1966 4.2 Coupe should be be pointed at the ends, or straight?
I've seen both. Suffolk and Turley certainly seem to produce pointed ends.
#2 Re: Luggage strips in S1 4.2 Coupe
Posted: Sat Jun 03, 2017 5:29 pm
Pointed:
Photos of original cars in our 4.2 Factory Fit thread:
viewtopic.php?f=4&t=2007
#3 Re: Luggage strips in S1 4.2 Coupe
Posted: Sat Jun 03, 2017 6:13 pm
by cactusman
Yep..all the ones I have seen are pointed.....and rare as rocking horse manure...
#4 Re: Luggage strips in S1 4.2 Coupe
Posted: Sat Jun 03, 2017 9:15 pm
by Michaelg
Many thanks for the replies. I thought as much. Now to convince my trimmer who should know better...
#5 Re: Luggage strips in S1 4.2 Coupe
Posted: Sat Jun 03, 2017 10:01 pm
Not sure that's correct.
I have pointed ones in my 3.8 coupe, but my June 1967 4.2 coupe has squared ones.
When was the changeover?
#6 Re: Luggage strips in S1 4.2 Coupe
Posted: Sat Jun 03, 2017 11:02 pm
All I can see is a big white box with some random parts in it
The FHC in the Factory Fit thread is a Jan 1966 car so at least pointy until then. A case of checking XKEdata photos and see if you can find a changeover point. But as the OP has '66 car I would say pointy is correct.
#7 Re: Luggage strips in S1 4.2 Coupe
Posted: Sun Jun 04, 2017 5:08 am
by Michaelg
Thanks Andrew and David. I'll do a bit more research before chiding the trimmers. It is a December 1966 car.
#8 Re: Luggage strips in S1 4.2 Coupe
Posted: Sun Jun 04, 2017 5:24 am
by Michaelg
From comparing the various photos on XKE Data (thank you David fror pointing me in that direction) it does seem that there was a change from pointy to square between May and July 1966. Problem solved I think. Thanks to you both.
#9 Re: Luggage strips in S1 4.2 Coupe
Posted: Sun Jun 04, 2017 6:14 am
Heuer wrote:All I can see is a big white box with some random parts in it
You can see the square ends on the foldy uppy thing.
And yes; a few bits of MGA I think..
#10 Re: Luggage strips in S1 4.2 Coupe
Posted: Sun Jun 04, 2017 6:01 pm
by Bertson
Hello,
my S1 2+2 hast the squared ones and is from May 1966....
#11 Re: Luggage strips in S1 4.2 Coupe
Posted: Sun Jun 04, 2017 6:06 pm
abowie wrote:Heuer wrote:All I can see is a big white box with some random parts in it
Ahh, see it now Andrew. I was searching the box!
