Under dash millboard panels-3.8
david muir
Scotland
#1 Under dash millboard panels-3.8
Post by david muir » Fri Jun 16, 2017 9:31 pm
Should the under dash panels on my '64 3.8 be in millboard or aluminium( car is late 3.8 so has centre and door armrests)? Also, if it's millboard , are they then covered by hardura mat in the trim colour? If it's aluminium , are these covered in the trim coloured 'leathercloth' ?
1964 3.8 FHC
david muir
Scotland
#2 Re: Under dash millboard panels-3.8
Post by david muir » Fri Jun 16, 2017 9:38 pm
okay, just had a look at the 'Original Fit' section!........looks like they were/should be black millboard !
1964 3.8 FHC
Philk
#3 Re: Under dash millboard panels-3.8
Post by Philk » Fri Jun 16, 2017 11:31 pm
david muir wrote:okay, just had a look at the 'Original Fit' section!........looks like they were/should be black millboard !
Interestingly, I had a similar question since one of my panels is missing. The remaining ones are aluminium on my June '64 3.8
1964 S1 3.8 OTS
david muir
Scotland
#4 Re: Under dash millboard panels-3.8
Post by david muir » Sat Jun 17, 2017 8:43 am
Mine too-although the 'middle' one looks to be homemade. I'm only missing the one at the far off-side!
[March '64 car]
1964 3.8 FHC
Moeregaard
#5 Re: Under dash millboard panels-3.8
Post by Moeregaard » Sat Jun 17, 2017 12:31 pm
My very early and unmolested 4.2 (1E30036, built 9/64) had vinyl-covered alloy panels under the dash. I couldn't find any reference (probably didn't look hard enough at 5:00 AM) in Haddock's restoration guide, but my guess is that the change to hardboard took place early in 1965, when a host of other features unique to the 3.8 were replaced.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Mikael B
Sweden
#6 Re: Under dash millboard panels-3.8
Post by Mikael B » Sun Jun 18, 2017 4:18 pm
My later S1 OTS-66 has the aluminium under dash
panels however covered in something else than vinyl and same as if you look in the 3.8 factory fit pages.
Mikael Berg
S1 OTS-66 Carmen Red; S1.5 2+2-68 Opalescent Maroon
