While the passenger's side under dash panel is present on my car, the driver's side one (or one of them) is missing.
It seems that it was removed to install an electric switch (red one) for forcing the radiator's cooling fan, also maybe because he had issues with one of two radio tweeters installed.
In the spare parts I was given with the car there is the following panel:
I have two questions:
1. Is that spare panel an original one that was drilled to install the radio tweeter or was it made by the PO and if so, can you confirm it should be installe on the left side of the steering shaft?
2. And are panels available for the right side of the steering shaft?
Thx for your help
Serge
