#1 Photo under Sugar Scoop?
Posted: Sat Jul 15, 2017 4:39 pm
by Philk
Does anyone have a photo of the inside of a S1 bonnet under the Sugar Scoop. I am trying to see what should be there (and what is missing) in terms of horn mounting brackets. This is so I can throw away my horrible after-market ones (which are sitting it in the front air intake!!) and then fit the proper WT618 units. I've looked through the factory fit pages and, whilst there is a picture of the horn inside the wing, it is not zoomed far enough out in order to see everything I need to. Many thanks!
#2 Re: Photo under Sugar Scoop?
Posted: Sat Jul 15, 2017 5:56 pm
Whether there is anything missing rather depends on the date your car was built . I can't answer the question of when things changed , but various S1 cars had underbonnet horns, and others had them attached to the picture frame, which is a much more convenient location
#3 Re: Photo under Sugar Scoop?
Posted: Sat Jul 15, 2017 10:31 pm
by Philk
christopher storey wrote:Whether there is anything missing rather depends on the date your car was built . I can't answer the question of when things changed , but various S1 cars had underbonnet horns, and others had them attached to the picture frame, which is a much more convenient location
Mine is a June '64 3.8. From everything I've read, it should have the horns in the bonnet. I believe some of the very first 4.2s had these too prior to them being moved to under the picture frame. Looking through the front intake, I cannot see the mounting brackets on either side.
#4 Re: Photo under Sugar Scoop?
Posted: Sun Jul 16, 2017 10:06 am
You can see them in the SPC diagram with an arrow helpfully pointing at one of them.
#5 Re: Photo under Sugar Scoop?
Posted: Sun Jul 16, 2017 12:05 pm
by Philk
Hi David
That is great - thank you. Unfortunately, looking through the horn apertures, these mounts are missing. I am guessing a replacement lower panel was used when my car was restored back in 1985 by the PO which did not have the mounts present. Do you know if anyone makes these, or is it a case of fabricating from scratch? I can't see any reference in the normal suppliers' catalogues.
I would really like to have them present so that the correct horns can be bought and placed in the correct position.
#6 Re: Photo under Sugar Scoop?
Posted: Sun Jul 16, 2017 12:58 pm
First port of call would be Hustons - speak to Andy as he will tell you if they are available anywhere in the UK. Failing that I would speak to Chuck at Monocoque Metalworks in the US as they have them:
#7 Re: Photo under Sugar Scoop?
Posted: Tue Jul 18, 2017 9:07 am
by ralphr1780
This might be of help, you can see the 2 horn brackets:
#8 Re: Photo under Sugar Scoop?
Posted: Thu Jul 20, 2017 8:57 am
by Philk
These are very helpful - thank you.
#9 Re: Photo under Sugar Scoop?
Posted: Thu Jul 20, 2017 3:35 pm
by andrewh
I bought a set of brackets for my series one in the UK. but cannot recall who from. I know they are made in aluminium, it may have been Hutsons.
#10 Re: Photo under Sugar Scoop?
Posted: Thu Jul 20, 2017 6:12 pm
by neil4444
Hutsons made some for me as they weren't on my replacement (Heritage) bonnet.
