seat Belt upper mounting point
Philk
#1 seat Belt upper mounting point
Post by Philk » Sat Oct 07, 2017 4:37 pm
Hi, before I go about peeling back/cutting into glued down material in order to find the upper seat belt mounting point on my 1964 3.8 OTS, does anyone have a photograph showing precisely where these are? I've seen a factory diagram but that is not much help in terms of preciseness of where to make the incision! I'm then hoping to find the plastic dummy screw in situ that I can then replace with the seat belt anchor bolt.
Many thanks!
1964 S1 3.8 OTS
rfs1957
#2 Re: seat Belt upper mounting point
Post by rfs1957 » Sun Oct 08, 2017 2:36 pm
Phil,
If you're going to put the reels in the boot-space I can help you, with "fresh" advice, having just done it - indeed I was about to update this post
viewtopic.php?f=3&p=92345#p92345
and then continue it with advice on dimensions and fitting.
The set-up I have is now perfect, but I effectively did it twice with a 10 year gap in between - and didn't get it right first time.
I would advise against putting them in the cockpit with regard to the hood. Also, IMHO it looks a mess. There are no down-sides to sticking them behind the bulkhead, other than having to cut slots and being prepared to take some care with getting a flat seating under the anchorage point.
Philk
#3 Re: seat Belt upper mounting point
Post by Philk » Sun Oct 08, 2017 9:53 pm
Hi Rory
Thanks for that. I'd seen the inertia belt installations on the forum previously. To start with though, I'm just doing static 3 point belts and have paid for the US Lap Belts already fitted to the car to be converted to 3 point for MOT purposes. I may go for inertia belts when the car gets retrimmed at a future date. What is worrying me slightly is that the picture of your car "in the metal" is not showing the screw fixing points that I understood were pre-drilled at each corner of the shelf just in front of where the hood fits. Does your car have these?
1964 S1 3.8 OTS
Philk
#4 Re: seat Belt upper mounting point
Post by Philk » Mon Oct 09, 2017 7:14 pm
Having peeled back the hardura on top of the rear parcel shelf of my 3.8 S1 OTS, I can confirm that the upper seat belt mounting points are not there (unlike one of the pictures from other posts on the forum). Instead, I found the following on the web. Mine were located as indicated on the diagram.
1964 S1 3.8 OTS
