#1 Mossbox - wait in neutral?
Posted: Fri Oct 13, 2017 5:39 pm
I am slowly, but very surely, getting the hang of this Mossbox, now that I have my darling in my clasp. I am test driving and recording like a madman pending her return for correcting the gear lever gaiter and to fit a Powerlite high torque starter.
Of course, I am getting no work done at all. What a tragedy.
Some questions for old hands on driving the Mossbox:
First, I should point out that with the new clutch and the Redline MTL, the shifting is really good. Hill starts with handbrake are very good.
I find that it's a tad arbitrary when there's grind and when not. Grind into second seems to occur only when I don't match the engine speed well, or when accelerating fast from first to second to third. Grind into third is very rare and more like a tiny little fart than a grind. She never grinds to 4th. Sometimes reverse grinds a bit, but that's not an issue as one does it so seldom.
Grind into first is interesting. There's no synchro on first. If I come to a stop and immediately put her in first, careful that I don't put her in third or in reverse (which happens occasionally), there's no grind at all, but then I have to wait in gear with the clutch depressed. If instead I relax in neutral, then, when I engage first, there's a grind. Not massive, but palpable, and more often than not. Not sure why she should grind at idle out of neutral into first, but not when coming to a stop and engaging immediately out of another gear.
I am wondering what is better for the wear of the gears in the long run - stop and sit in neutral, and then engage with a grind, or go to first immediately and wait sitting in gear with clutch depressed?
