Re hanging my doors on the series 1 1/2 what are the 2 set screws on the hinges on door side for
Is it some factory alignment puzzled
Thanks in advance
Door hinges
#2 Re: Door hinges
The safety strap is fixed on with 2 panhead screws. But AFAICR there are 4 holes so the same hinges can be used the other way up on the other side of the car. Might that be the answer?
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#3 Re: Door hinges
I believe they were installed/drilled at the factory to help assure door alignment as the clamping force provided by the four set screws could be less than adequate. I found them to be very helpful with achieving alignment when reinstalling original doors and hinges.
Eric
