#1 FHC door frame fitment and rubbers
Posted: Sun Feb 11, 2018 3:18 pm
I am trial fitting my chrome door frames and quarter light prior to paint and am having a few problems.
Firstly, does anybody have a picture of how the rubbers should fit on the top rear edge of the frame?
It appears that the top rubber stops at about 1/16" before the end of the frame and the back side rubber goes up to about 1/16" from the top. I deduce this from the fact that the channel in the frame stops in this way.
This of course leaves a square missing between the two, which doesn’t look quite right?
The second problem is that there is not enough room between the back of the door frame and the quarter light hinge pillar for both the hinge pillar seal and the corresponding seal on the back of the door frame to fit, or more precisely to close properly.
The frame is about 1/4" from the A post/ windscreen pillar at the front and about the same at the back.
I cannot move the frame further forward without elongating the mounting holes, but this would obviously make the front gap smaller.I cannot move the hinge pillar backwards ether because of the limitations with the mountings.
As there were no rubbers on the doors when I bought the car and I have restored the door frames and skins, I am not sure how close the gaps would have originally been.
The hinge pillar rubber and frame rubber seem to interlock according to the diagram in the parts manual; is this correct?
Thanks,
Thanks,
