IRS access panels
baliniere
#1 IRS access panels
Post by baliniere » Fri Feb 16, 2018 5:36 pm
I own a late 1968 Series 2 2+2 which has been four years in a total bare metal strip down and rebuild.
I am now setting up the brakes and getting her ready for the road.
I removed the two panels on the front of the IRS tunnel behind the rear seats without problem
I also removed the panel on top of the IRS tunnel to allow access to the handbrake set up, but the cover was not servicable am am looking to replace it with a new or second hand cover.
Here is my problem..
No one can suppy a new top cover and everyone l have spoken to who supplies parts tells me that they have not seen or heard of a top access panel for he lRS tunnel.
I could just make one but l would prefer the real thing to match the quality of the restoration..
Can anyone help me find this panel. Or tell me if they have ever seen or heard of this panel??
Nick
#2 Re: IRS access panels
Post by cactusman » Fri Feb 16, 2018 6:07 pm
My series 1 3.8 has the panel on top of the IRS but not the ones behind the seats. I think the two behind the seats were fitted to later cars and possibly just the 2+2 cars although others will know better.
#3 Re: IRS access panels
Post by christopher storey » Fri Feb 16, 2018 6:43 pm
The panels behind the seats are for 2+2 cars only . The top access panels were widely fitted to series 1 cars , but seem to have been less widely fitted from S1.5 onwards, although my S2 OTS has one which I am quite sure is original. The factory panels themselves are well made, rhomboid in shape and about ( at a guess ) 450mm wide and 200mm fore and aft, with several stiffening indentations pressed into them . I do not have a pic of the plate itself, but here is one of the floor beneath the plate which shows the shape : the indentations in the plate correspond roughly to the holes in the floor
baliniere
#4 Re: IRS access panels
Post by baliniere » Sat Feb 17, 2018 10:11 am
Thanks Guys you have restored my faith in my sanity..
I have heard in the past the Jaguar used up the bits in the parts bin when they started a new Series so it is possible that the IRS panel was from a Series 1 or 1.5 which ended in 1968. The Series 2 came in late in 1968 and that is when my car came off the line
I will now try again to source this bit from suppliers with the info that you gave me..
Any ideas where to go?
Nick
Bob.
#5 Re: IRS access panels
Post by Bob. » Sat Feb 17, 2018 1:39 pm
Happen to have this picture labled "1963 FHC"- might help.
Bob
'71 S3
baliniere
#6 Re: IRS access panels
Post by baliniere » Sat Feb 17, 2018 4:27 pm
Thanks.. l will send the photos to suppliers so that they can see that l am not crazy..
Nick
Polse7317
#7 Re: IRS access panels
Post by Polse7317 » Sun Feb 18, 2018 3:52 pm
Here what i have on my 63 FHC
:yellow:
baliniere
#8 Re: IRS access panels
Post by baliniere » Sun Feb 18, 2018 5:19 pm
If all these cars have the panels as shown in the photos then why can l not buy a replacement panel???. Anywhere...
Even Jaguar say they don’t have them yet they are restoring ETypes themselves...
#9 Re: IRS access panels
Post by mgcjag » Sun Feb 18, 2018 6:14 pm
vikla
#10 Re: IRS access panels
Post by vikla » Sun Feb 18, 2018 6:36 pm
I think the part in question is BD18492.
On my 1966 4.2 FHC I don't believe the cut out holes had been factory provided. But it was clear a previous owner had just taken some tin snips and made a very messy hole in the metalwork to get to the IRS.
As a result I wanted to have the correct panel to cover up the mess.
I ordered one from David Manners who seemed to have one reasonably priced. When I got it I realised why, it was just a piece of plain aluminium sheet cut to shape. They still list it for £15 + VAT.
The Barratts one is much more expensive - https://www.sngbarratt.com/uk/#!/Englis ... c50a359e27
This looks similar to the Manners one but just painted black and also with no pre-drilled screw holes.
The Welsh Enterprises one seems to be the real thing - http://www.welshent.com/product_info.ph ... 79_189_194
S1 4.2 FHC 1966
