Heater pipes
Welsh62fhc
#1 Heater pipes
Post by Welsh62fhc » Tue Feb 20, 2018 3:29 pm
Hi I am fitting new heater pipes before painting car, should the plates on the ends with 3 rivet holes be left black, or painted body colour.
Also every rivet gun I can find won't allow the rivet to pull up square, the pipe gets in the way of the gun.
Thanks Gary
Jeremy
#2 Re: Heater pipes
Post by Jeremy » Tue Feb 20, 2018 3:53 pm
The pipes and the front plates on my car were all painted black Gary. Have a look at all the photos in the Factory Fit threads which are particularly helpful in identifying correct paint finishes.
I put a small nut on the shaft of the pop rivet to act as a spacer between the gun and the rivet head, and that solves the problem of fouling with the pipe.
Jeremy
1967 S1 4.2 FHC
Welsh62fhc
#3 Re: Heater pipes
Post by Welsh62fhc » Tue Feb 20, 2018 4:02 pm
Thanks for that tip Jeremy
