#1 Front suspension torsion bars
Posted: Sat Oct 24, 2009 12:00 pm
by norman m. macleod
I am undertaking a ground-up restoration on a Series I 2 + 2. The car has a recorded 90,00 miles on the odometer. My question is, do the front suspension torsion bars have a recommended "life", or should they be replaced as a matter of course......? All advice welcomed
Thanks Norman.
#2 torsion bars
Posted: Sat Oct 24, 2009 1:00 pm
by Larry Wade
Hi Norman,
The bars themselves are fine. The only reasons to replace them are if the car has been in a front end accident, if they are heavily corroded or if you want to go racing. If you want to change the ride height, you'll need to change the preload on the bars, not the bars themselves.
Great design!
Cheers,
Larry
Posted: Sat Oct 24, 2009 2:33 pm
Hi Larry,
Thanks for that reassurance....mind at rest now! Had thought about replacing on account of age only....They are undamaged and rust-free, so will refit.....Thanks for your help.....
Norman
Perth, Western Australia.
Posted: Sat Oct 24, 2009 2:52 pm
by daverawle
norman m. macleod wrote:Hi Larry,
Norman
Norman,
they are 'handed' so have to go back on the correct side; they are stamped on one end. Just in case you didn't know.
Posted: Mon Nov 02, 2009 1:00 pm
Hi there Dave
Thanks for that, I didn't know they were handed, well noted. Apologies for the inordinate delay in response, but I have been out of Oz briefly....I hope to commence dismantling the front suspension shortly, so no doubt there will be some more queries as we go.....!
Thanks again,
Kind regards,
Norman, Perth, Australia.
Posted: Mon Nov 02, 2009 10:03 pm
by vipergts
Handed......holy crap.
Why are they handed do you know......different strength?
Posted: Mon Nov 02, 2009 10:32 pm
by christopher storey
They are handed because they deal with bump and rebound which are dynamically quite different, and are set metallurigically to be stiffer IIRC on bump than on rebound. If you put them on the wrong side they will sag in no time at all
