I have a problem with my final drive unit (differential). It is not possible to pull out the companion flange assembly (Jag item no. 3879). Neither with a polling nor with heating does works.
Thanks Jonas
final drive unit
#2 Re: final drive unit
You mean the input flange?
Mine would not come off either. I actually bent it and had to buy a new one in the end.
I used the correct puller, heat everything.
