#1 Which brake fluid
Posted: Wed May 09, 2018 6:50 pm
by jamesmatheson
Hello everyone, I have s1 2+2 , which brake fluid is best recommended to use please?
James :bigrin:
#2 Re: Which brake fluid
Posted: Wed May 09, 2018 7:12 pm
by phil.dobson@mac.com
If you are not using silicone then I just use a standard DOT 4 mineral fluid.
#3 Re: Which brake fluid
Posted: Wed May 09, 2018 8:30 pm
by chrisfell
Subject comes up quite regularly. I use 5.1. It is not expensive and has a higher heat threshold than 3 or 4.
A point to note. The new MOT rules include a visual check on the condition of brake fluid. Dirty fluid is a fail.
#4 Re: Which brake fluid
Posted: Sun May 13, 2018 5:00 pm
by Fasthound1963OTS
The guys at R&R Auto (Sterling, VA, USA) who’ve been keeping British cars on the road since the mid-1970’s swear by Castrol, so that’s what I am using.
#5 Re: Which brake fluid
Posted: Tue May 15, 2018 5:18 am
by jamesmatheson
Thanks for the reply’s, any idea on the quantity needed for a full system change?
#6 Re: Which brake fluid
Posted: Tue May 15, 2018 6:55 am
by cactusman
If you are just rinsing through a filled and air free system and not trying to force air bubbles out then a litre should be plenty. If you are filling an empty system and need to force air bubbles out you will probably wind up using more than a litre... :bigrin:
#7 Re: Which brake fluid
Posted: Thu May 17, 2018 10:15 pm
by Jeremy
I filled my brake and clutch systems from empty, that's new everything and completely empty, and bled them, with 1 litre. There was a bit left over, not much. If you're flushing out old/contaminated stuff I think you would need more.
