#1 Fosseway brake upgrade
Posted: Sun May 13, 2018 4:46 pm
Just thought I’d post some photos and info related to my Fosseway brake upgrade installation. First, kudos to Simon at Fosseway for great communications. He answered all my questions quickly and was pleasant to deal with. I had a very minor issue that he resolved quickly for me over the weekend.
I chose to go with the basic upgrade to larger lightweight calipers only as opposed to vented rotors which I decided would be a bit of overkill since I don’t plan on any track or auto-cross events and I’m not particularly concerned about brake fade from heat buildup. And reverting back to the original setup will be very easy if desired since no hub removal, etc.
I’ve included photos showing the upgrade in process. I forgot to take photos of the kit before I started this install, but you can see the calipers and the brake lines and the pads, etc. I’m quite lucky to have a lift with bridge jacks in my garage, so that made the whole process even simpler.
While I haven’t finished yet, so far it’s been very simple. I was a little worried about removing the dust shield (having not done it before and since none of the manuals say how to do it), but it was very straight forward and simple. Took just a few minutes to take off the shields and then another couple of minutes to remove the old calipers.
Assembly of the brake kit brackets onto the new calipers and loading up the new pads, etc. was quite simple. Routing the new braided line took a bit of a think and some experimentation to make sure there would be no rubbing, but also rather straight forward. I have to say the quality of the materials of the calipers and brackets and braided line is quite nice and the instructions are easy to follow.
Once I’ve finished the install and bled the system and done some road tests, I’ll follow up this posting.
Cheers,
Kevin
Cheers,
Kevin
