I am undertaking a ground-up restoration on a Series I 2 + 2. The car has a recorded 90,00 miles on the odometer. My question is, do the front suspension torsion bars have a recommended "life", or should they be replaced as a matter of course......? All advice welcomed
Thanks Norman.
Front suspension torsion bars
norman m. macleod
Topic author - Posts: 227
Larry Wade
#2 torsion bars
Hi Norman,
The bars themselves are fine. The only reasons to replace them are if the car has been in a front end accident, if they are heavily corroded or if you want to go racing. If you want to change the ride height, you'll need to change the preload on the bars, not the bars themselves.
Great design!
Cheers,
Larry
Great design!
Cheers,
Larry
Larry Wade
62 OTS 877842
La Canada, California, USA
62 OTS 877842
norman m. macleod
Hi Larry,
Thanks for that reassurance....mind at rest now! Had thought about replacing on account of age only....They are undamaged and rust-free, so will refit.....Thanks for your help.....
Norman
Perth, Western Australia.
Norman
Norman,norman m. macleod wrote:Hi Larry,
Norman
they are 'handed' so have to go back on the correct side; they are stamped on one end. Just in case you didn't know.
1963 OTS
norman m. macleod
Hi there Dave
Thanks for that, I didn't know they were handed, well noted. Apologies for the inordinate delay in response, but I have been out of Oz briefly....I hope to commence dismantling the front suspension shortly, so no doubt there will be some more queries as we go.....!
Thanks again,
Kind regards,
Norman, Perth, Australia.
Thanks again,
Kind regards,
Handed......holy crap.
Why are they handed do you know......different strength?
S1 4.2 Roadster in Resale Red
They are handed because they deal with bump and rebound which are dynamically quite different, and are set metallurigically to be stiffer IIRC on bump than on rebound. If you put them on the wrong side they will sag in no time at all
