#1 1963 FHC - hatch trim piece around lock.
Posted: Wed Jun 27, 2018 9:48 am
Hi All,
I am prepping for the retrim of the rear hatch door and wanted to clarify how the trim piece is attached to the lock mechanism area. It has a triangular hardboard piece with holes and foam and is pre-stapled to the vinyl. The holes align to the door holes (good start!) but I need to check the following:
1. Does the trim piece sit on top of the top and bottom trim panels, or tuck underneath?
2. Have I got it the right way up as per the pic 2?
3. Is it held in place by just the lock mechanism or does it get glued on as well?
4. Does it fit as per pic 2, then the vinyl folded over/around the mechanism as per pic 3?
TIA
TIA
