#1 3.8 Choke Cable, Clamp For Outer At Lever
Posted: Sat Oct 20, 2018 4:47 pm
by glennglenn
Is there a clamp to suport the outer cover in the cockpit by the choke lever? Mine seems to be too lose when putting choke back to cold normal running, the chokes are not fully releasing.Also what’s the correct route for the cable, I know this has been covered before but the images have been erased. Thanks!
#2 Re: 3.8 Choke Cable, Clamp For Outer At Lever
Posted: Mon Oct 22, 2018 5:34 pm
by Fasthound1963OTS
This might help. I finally routed mine similar to the photos shown near the end of the thread.
https://forums.jag-lovers.com/t/choke-c ... /352541/11
#3 Re: 3.8 Choke Cable, Clamp For Outer At Lever
Posted: Sat Nov 17, 2018 7:03 pm
by mark10337
http://forum.etypeuk.com/viewtopic.php? ... ram#p80556
The choke cables are routed via the hole labelled ??? on the bottom line of the diagram.
