#1 Advice on 2+2 rear wheelarch inner panel
Posted: Wed Oct 31, 2018 4:22 pm
by H7OB
Could anyone point me in the direction of an image and / or a source for the component that creates the armrest area that runs off the wheelarch in the second row of a 2+2? My interior was not original and had what appeared to be a hand made sheet steel part at one side and a similar one in aluminium riveted to the front surface of the rear wheelarches at the other. These had foam glued on, beneath the trim. Neither of which looked original. I will also be looking to create a seatbelt run within this for my newly added inertia reels. I’m struggling to find anything that shows the break up in this area. Any help much appreciated!
#2 Re: Advice on 2+2 rear wheelarch inner panel
Posted: Wed Oct 31, 2018 5:04 pm
Hi Paul...what you describe sound about right...a home made looking metal panel covered in foam as mine here
Image and here completed .. note that i have split the wheelarch trim the join is where the rear seat fits so is hidden quite well its not easy making a neat job of the seatbelt entry/exit...if you need any help pm me... Steve
#3 Re: Advice on 2+2 rear wheelarch inner panel
Posted: Wed Oct 31, 2018 5:08 pm
This may help also
#4 Re: Advice on 2+2 rear wheelarch inner panel
Posted: Wed Oct 31, 2018 5:55 pm
by H7OB
Steve, youre a hero, thats exactly what I was looking for. Im now glad I didnt throw anything out, as home-made as it looked! Youve also done exactly as I plan to on the seatbelt. Could I ask where you got the bezels from? Ive bought a pair of black plastic parts but chrome would look better. I imagine that whole area will be a fun job, particularly when that contact adhesive takes hold!
:thankyouyellow:
#5 Re: Advice on 2+2 rear wheelarch inner panel
Posted: Wed Oct 31, 2018 7:02 pm
Hi Paul...i assume you mean the chrome part where the belt comes through....its called an escutcheon....so search for that..mine were from CMC they are about £40 each........you get the top chrome part and a bottom unchromed plate to fit under........you will have to alter the top of the metal panel to make it a bit wider to fit..Steve
#6 Re: Advice on 2+2 rear wheelarch inner panel
Posted: Wed Oct 31, 2018 8:58 pm
by H7OB
Thanks again Steve, much appreciated.
:salute:
