Boot Board Hinges
Steve390
#1 Boot Board Hinges
Post by Steve390 » Thu Nov 08, 2018 7:04 am
The hinges for the fold down boot board as listed on SNGB as BD24400.
Were there different hinges used early on? I cant find any holes or indication of hinges that would work in the way the above hinge does.
But there does appear to be holes that would allow for a simple flat piano hinge.
paulsco
#2 Re: Boot Board Hinges
Post by paulsco » Thu Nov 08, 2018 10:22 am
Hi Steve,
I think earlier cars had door like hinges; I assume the 3.8's, but I don't know until when.
You dont say what year your car is.
Steve390
#3 Re: Boot Board Hinges
Post by Steve390 » Thu Nov 08, 2018 10:39 am
Thanks Paul, early 62.
edriver
#4 Re: Boot Board Hinges
Post by edriver » Thu Nov 08, 2018 5:53 pm
your three hinges should be BD20131
Fitted from Chassis No.
860581 to 861098. 886093 to 888301.
The later hinge is BD24400
Fitted to Chassis No.
861099 and subs. 888302 and subs.
BTW BD23142 is for the hinged panel striker and not a hinge.
Hope this helps,
Klaus
Klaus
Steve390
#5 Re: Boot Board Hinges
Post by Steve390 » Thu Nov 08, 2018 6:50 pm
Thank you Klaus. Correct my mistake. Read the wrong line. :-)
