#1 Tappet/timing chain noise
Posted: Sun Dec 09, 2018 5:13 pm
Hi all,
Having had the cylinder head shimmed I have since been driving for 50 miles or so and am noticing an improvment in tappet noise but it is still not as quiet as I expect it should be. The noise seems to be intermittent depending on rpm, and i would say is quieter when engine warm.
The noise I think it coming from the front left so exhaust side. I expect one of two things at present, the 1st or 2nd from front followers are badly shimmed or the timing chain adjuster needs tightening and the noise I’m hearing is potentially the chain slack.
I had a peak inside the cam cover and found some scoring on the top of the 2nd from front follower, il take the cover off for a better look but wanted to share the photo here in case anyone has seen similar. To me it looks quite bad, and I worry about the route cause. Wondering if oil starvation at that lobe could do such a thing.
