#1 Front brake flexi hose mounting bracket - Photos
Posted: Sat Jan 12, 2019 5:44 pm
by E600
Could someone please post a picture of the front flexi hose bracket for a s1 3.8, the one on the picture frame not the hub. I have a selection that don't appear correct and can't find info on suppliers web sites, nor pictures on the web.
Thanks in anticipation.
Pat
#2 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sat Jan 12, 2019 8:05 pm
by cactusman
I'd be interested as well. Mine has two distinctly non original looking stainless steel brackets.....
#3 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sat Jan 12, 2019 9:19 pm
Have you looked through the factory fit section......post 2 showes one.....there may be others if you look through the whole section.....Steve
#4 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sat Jan 12, 2019 10:31 pm
by Jeremy66
Don’t know if this helps (mine is a 4.2)
#5 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sun Jan 13, 2019 12:58 am
by E600
Thank you both, Steve, I have now trawled through all 13 pages of Factory Fit and found 3 photos on which to base a decision. Interestingly there is a big difference between 3.8 and 4.2, not only in shape and location but also in how the flexible hose is presented to the hub bracket. The 3.8 faces forward and the 4.2 presents to the outside of the frames. There must be a reason as the 4.2 bracket is far more complex, larger and must have been more expensive to buy. Perhaps there were issues on the 3.8’s with the hose fouling or being stretched through too great an arc?
To confuse matters more the S3 goes back to a 3.8 design, curioser and curioser
Thanks again
Pat
#6 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sun Jan 13, 2019 1:40 am
1963 FHC.
#7 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sun Jan 13, 2019 12:12 pm
From 'Factory Fit':
#8 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sun Jan 13, 2019 5:05 pm
by cactusman
Well there you are.....mine looks just like Andrews....although my plates seem to be stainless steel....
maybe they are more or less correct?
#9 Re: Front brake flexi hose mounting bracket - Photos
Posted: Sun Jan 13, 2019 10:44 pm
by ysmalkie
Same on mine 3.8:
and the colour is the same as the seats:
Tadek
#10 Re: Front brake flexi hose mounting bracket - Photos
Posted: Mon Jan 14, 2019 8:08 am
by cactusman
My bits and pieces look just like Tadeks although I think a previous owner has cut stainless steel sheet for the brackets.....They are metal finish and seem not to rust so I presume t hey are ss.
