#1 3.8 FHC hatch stay receiving bracket
Posted: Sat Feb 02, 2019 6:46 pm
by rswaffie
I am hoping someone can help me with an answer to this question.
The rear hatch lid stay locates in a bracket, which seems to be fixed using setscrews and domed nuts as in a pic I found on the forum:
I’m assuming that there should be a couple of holes in the gutter to allow it to be fitted? My panel was replaced and there were none pre-drilled. Is that correct?
#2 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 12:32 am
I'll be interested to see the answer as I seem to have the same problem.
#3 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 8:10 am
by Simonpfhc
Hi Richard,
Yes, you are correct; there should be two holes in the lower gutter. Despite having taken a gizzilion photos, this is the only picture I can find where you can clearly see them:
Let me know if you need a measurement of where they should be.
Cheers.
#4 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 8:12 am
by Jeremy
Richard, this probably isn't much help, but the later (hinged) design has the bracket fixed with self tappers that plunge into the blind cavity below the gutter. (Mine had all that section replaced so I had to drill new pilot holes). Can't see how you'd have access to do much else. Unless captive bolts or nuts were welded to the body during production?
#5 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 8:30 am
by Jeremy
Simon beat me to it. Ignore my post!
#6 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 10:49 am
So what goes thru the holes?
#7 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 10:56 am
by rswaffie
Gents,
Many thanks for the replies.
It’s confirmed what I suspected- I need to drill some holes in the gutter.
Like Simon, I also struggled to find anything in my huge collection of strip-down pics - this was the best I could come up with which was from the bodyshop - you have to zoom in to see the holes! I’ve had the fittings rechromed since theses were taken!
#8 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 10:59 am
by rswaffie
Andrew, there are two slotted setscrews with domed nuts, although sng only list plain nuts from memory. I’ll need to check in the factory fit/parts section to confirm what is correct. Mine deffo had domed when I took it off.
#9 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 1:34 pm
by edriver
Richard,
I have used a (metric
) M5 stainless dome nut (DIN917) and I would do it again! The sharp edges of a protruding setscrew could damage the luggage. The 3.8 parts handbook
calls for your E for 2 standard nuts UFN.119/L
UFN. Fine Thread Nut, non-locking
1 Standard Hex Nut
19/ 3/16", 32TPI, screw size #10
L steel
The set screw is BD.13713/1 and the shakeproof washer is C.723/A and can be obtained from SNG.
Since I was going non-original already, I used a slotted M5x12 set screw with a very flat head (called Becherschraube or Tellerschraube in Germany). Its head fits neatly under the hatch door seal. I have even added a plain washer under the shakeproof washer to match the screw length to the height of the domed nut.
Please forgive me, fellow forum users
#10 Re: 3.8 FHC hatch stay receiving bracket
Posted: Sun Feb 03, 2019 4:58 pm
by rswaffie
Thanks chaps,
I’ve now found where the holes were in the gutter (welded over) and got it installed. The lower trim panel helped line it all up.
#11 Re: 3.8 FHC hatch stay receiving bracket
Posted: Fri Apr 23, 2021 5:53 pm
by Series1 Stu
Hi Chaps
Reviving this thread as it is particularly relevant for me today. I too did not have the original holes in the gutter for the prop bracket so this thread was a godsend for me.
However, can anybody tell me what the heads of the screws BD13713/1 look like please? I probably have them in my stash but need to know what I'm looking for (I didn't dismantle the car).
I'm all set ready to install, just need the correct screws.
Regards.
#12 Re: 3.8 FHC hatch stay receiving bracket
Posted: Fri Apr 23, 2021 7:41 pm
by edriver
Screw #10 UNF x 3/8" Panhead Slotted - BZP Finish
