Rad & fan install
peters3103
#1 Rad & fan install
Post by peters3103 » Fri Feb 08, 2019 5:35 am
Hi all,
I’m about to fit my new Radtec radiator and am proposing to use the existing Kenlowe fan which is currently installed with nuts and bolts through the core. Obviously I don’t want to use this method and need to fabricate some brackets to attach the fan unit to. Any suggestions on how/where to attach said brackets? Would the shroud be strong enough to support the fan or is that asking for trouble?
Cheers,
#2 Re: Rad & fan install
Post by cactusman » Fri Feb 08, 2019 7:14 am
I'd say asking for trouble. It is some kind of fibre glass I think. If original it will probably be brittle and even if new probably not strong enough. My advice....a coolkat fan. Fits on the original mount and pulls a lot of air. Fits perfectly within the shroud. Great piece of kit.
peters3103
#3 Re: Rad & fan install
Post by peters3103 » Fri Feb 08, 2019 10:53 am
Agreed, my only problem is that some twat has cut half the original fan motor bracket off to allow room for the Kenlowe motor. It will need repair or replacement. I do have an original motor & blade and it would be interesting to see how that fares with the more efficient radiator, however I think the Coolcat is the way to go.
Jeremy66
#4 Re: Rad & fan install
Post by Jeremy66 » Fri Feb 08, 2019 2:18 pm
I’ve mounted a Davies Craig fan in the gob on my car fixed to the stone guard pushing air through the radiator (it’s got a reversible blade so can be used as a puller and fitted inside the original fan cowl if needed but you’d have to make brackets). I also fitted the Davies Craig control unit which lets you select on / off temps etc, works well and can all be stripped off one day if needed.
It gives me peace of mind and the car will sit in a traffic jam and not go above 90 degrees c
Jeremy
https://www.merlinmotorsport.co.uk/p/di ... gJ5J_D_BwE
