#1 Brake control assembly - washer question
Posted: Sat Jun 08, 2019 2:13 pm
I am trying to assemble the shaft and pin assembly(9) to the connecting lever(11) with the operating arm (17).
The parts list lists 2 washers FW205T (5/16th" washers)
Would any of you know where they go? On the upper or lower pin?
Also, There seems to be an imbalance between the 2 pins - on one side there is the nylon bush, on the other there is nothing. Is this the way it's supposed to be?
Tadek
Tadek
