#1 parts questions
Posted: Wed Jun 19, 2019 10:11 am
by yev
hi guys
i have 2x questions:
just ordered new fuel tank from MR . my existing tank sump didnt screw all the way, so i ordered replacement one from SNGB ( i had load of other parts coming from them) but have exaclty the same problem.
is there a specific tank sump need to be used?
also- my current clutch master cylinder (p/n c26531) is leaking so i ordered replacment (p/n C27186) but it looks totally different.
i googled c26531 and nothing coming up.
SNGB answer to me on both : they supplied me correct parts for my car (S1 2+2)
anyone can explain this pls?
#2 Re: parts questions
Posted: Wed Jun 19, 2019 11:06 am
Hi Yev......the correct cylinder is C27186.......re tank sump the part is C19302.....but it screws onto a tank sump screwed ring part C19298....perhaps this part is faulty on your car......Steve
#3 Re: parts questions
Posted: Wed Jun 19, 2019 1:32 pm
by cactusman
I also seem to remember there is a seal that should be fitted when you screw the sump onto the tank....made of fibre or possibly cork?
#4 Re: parts questions
Posted: Wed Jun 19, 2019 2:47 pm
by yev
but screwed ring part C19298 is part of the tank? how do i replace it?
#5 Re: parts questions
Posted: Wed Jun 19, 2019 3:29 pm
Hi Yev......you have a new tank from MR.......Martin Robey i assume.....and a new sump from SNG......they dont fit together......suggest you call MR to see whats supplied and if the SNG sump should fit....is the sump ring already fitted to the tank...is it removable or comes permenantly fixed to the tank....is the thread damaged on either part and deep enough for both parts to fit together......Steve
#6 Re: parts questions
Posted: Wed Jun 19, 2019 3:41 pm
Not that it makes much difference unless you have a very early car but please can you add the model and date to your signature. Have you got all the pieces?
#7 Re: parts questions
Posted: Wed Jun 19, 2019 4:19 pm
by yev
hmm... maybe i have something missing.. let me check. thanks a lot.
car is not too early. ive added it on now to signature
#8 Re: parts questions
Posted: Wed Jun 19, 2019 8:48 pm
by Simon P
#9 Re: parts questions
Posted: Wed Jun 19, 2019 10:16 pm
He needs to talk to Rory, aka Mr Ducati!
#10 Re: parts questions
Posted: Thu Jun 20, 2019 11:36 am
by yev
who is Rory and why he is mr Ducati?
#11 Re: parts questions
Posted: Thu Jun 20, 2019 2:26 pm
Rory Simpson of Simpson Mécanique fame = rfs1957 on the Forum.
More here:
https://www.liberiders.tv/2018/11/21/du ... mecanique/
Great guy and valued Forum member.
#12 Re: parts questions
Posted: Sat Jun 22, 2019 12:47 pm
by yev
- IMG_6039.jpg (114.88 KiB) Viewed 7357 times
getting there. fuel sump sorted. going to rebuild my original clutch master cylinder.
