Apologies if I have missed an earlier post covering this but I couldn't see anything when I searched earlier. I am nearing completion of converting my 62 FHC to RHD and have located the washer bottle in its new position but I'm unsure where the wiring is meant to pass through the bulkhead. I was going to use one of the three redundant holes from where the throttle linkage sat above the heater valve but I'm sure that this isn't correct.
Any photos would be a big help
Many thanks
Graeme
Wiring route for washer bottle
#2 Re: Wiring route for washer bottle
Assuming you have a RHD engine bay loom it comes off the loom itself just near the heater motor wires, in the engine bay. So it doesn't go through the firewall.
If you have retained the LHD engine bay loom I am not sure.
