Lual
Post
by Lual » Wed Jun 26, 2019 3:31 pm
Hi all
Despite I am a member of the forum only for few weeks, I fall in love long time ago with these cars.
I am about to pull the trigger and sign for an S1 from Dec 1964. I will have tons of questions, as I know little about them, and also because mechanically speaking, I am unfortunatly very green.
I didn’t find it yet in XKEdata.
Below some pics,
Lual
Lual on Fri Jun 28, 2019 2:41 pm, edited 1 time in total.
- Moderator
Post
by mgcjag » Wed Jun 26, 2019 4:13 pm
Hi Lual.......have you actually been and looked at this car.......dont be in too much of a rush to buy and try to look at quite a few befor you buy......the door and bonnet do not look a very good fit in the photos......Steve
Moeregaard
Post
by Moeregaard » Wed Jun 26, 2019 5:04 pm
Steve has good advice. I would never buy an E-Type (or any car) unless I had a couple of days to look it over--and this includes spending a good deal of time under the car. An E-Type is one of those cars that can seriously bite an unwary buyer. If you can take along someone who is intimately familiar with E-Types--and one who can talk you out of making a mistake--please do so. These cars are not rare, so it's worth examining several before making a decision.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Lual
Post
by Lual » Thu Jun 27, 2019 11:39 pm
Thanks to both of you for your advices. Yes, I have had somebody knowledgeable looking into the car. This person, who took the picture told me door was not properly closed, but was presenting no issues .
Regarding the bonnet, apparently this was replaced by a fiber one to improve handling. But here I cannot judge if this is normal or if this was due to any damage into the original one.
- Moderator
Post
by mgcjag » Fri Jun 28, 2019 7:43 am
Hi Lual......replaceing the bonnet for a fibre to improve handling does not sound right.....aluninium bonnets are used for a lighter weight for race cars but then other modifications to the handling would also be made.....the car needs a good inspection for other damage if the original bonnet was damaged......a fibre bonnet will seriously decrease the value of the car....but it still does not look like it fits properly......Steve
Post
by malcolm » Fri Jun 28, 2019 8:24 am
It's fitted with non-standard Weber carbs. Not necessarily an issue I suppose, but may prove problematic? Not something you fiddle with yourself unless you're an expert I'm led to believe.
Post
by politeperson » Fri Jun 28, 2019 10:14 am
Whether it is good or bad depends on the price. How much is it?
- Administrator
Post
by Heuer » Fri Jun 28, 2019 10:21 am
I would run a mile from that car - it is a disaster waiting to happen. If someone has bodged the bonnet with a fibreglass one then expect the same dismal and cheating ("fibre glass bonnet fitted to improve handling"
) approach to be used elsewhere.
Lual
Post
by Lual » Sat Jun 29, 2019 6:14 pm
Thanks for all wise comments / advises.
Based on them, it is clear I need the car to be inspected by an independent classic car dealer with a mechanic. Seller still keeps the original bonnet which goes with the car. I think it is worth to do so, rather than taking a final conclusion based on a couple of pictures and a comment (fiber bonnet) that may be totally wrong (aluminium instead), as it was not coming from the seller.
Will update,
Lual
Moeregaard
Post
by Moeregaard » Sun Jun 30, 2019 2:20 pm
I'd look at few more cars before settling on this one. I'm just seeing too many red flags here--the fibreglass bonnet, etc. Even if the seller is asking for a ridiculously low price, keep in mind that a cheap E-Type can be one of the most expensive decisions you ever make. Find a clean original car, or one that has a well documented restoration.
Mark (Moe) Shipley
